CHOOKS
so i have a change, its a 2f0 thats a 1980, and already has the pick up on the stator.
please help>
please help>
Just swap out the Cap for a Battery. Works the same way.
On your 80 left switches the headlight dimmer switch has A yellow, That's high beam, A yellow/red, that's power in, A dark green, that's low beam. the blue/green and yellowblue worked with the light checker and reserve lighting unit and safety relay to turn the lights on after the bike starts and turn one headlight beam on when the other blows out.
On a home brewed harness ignore these wires. All you need is the power in and out to the headlight. The red/yellow power in should be hooked to a switch so you can turn the headlight off to start the bike then back on when running.
On the Turn switch you have A Dark green wire, power out to right side. A brown/white power in from the flasher. A chocolate wire, the one I think you call maroon, power out to left side. A red/yellow wire, this works with the self canceler, ignore it. The black just ground it.
The horn button, a pink wire. Power goes to the horn, from the horn to the button, when pushed the button grounds and the horn toots.
On the engine stop switch the brown wire is power in the red/white is power out. hook the brown wire in after the main switch, the red/white out to the ignition.
