trance
Ok, I've got the engine out of the frame. Before I removed it, the starter was working, but grinding and not disengaging right away.
I'm assuming that I need to take a look a the springs, and plan on pulling the cover tomorrow. couple of questions:
1) Is the correct order of operations: a) remove right hand side cover b) remove clutch c) then I can get at starter gears?
2) anything I need to be aware of or watch out for?
3) can you point me towards any how-to guides on fixing the springs? I've seen several that say you should remove the wishbone shaped spring and tighten it (but I can't figure out how to tell if it's tight enough) and also retension the other spring (but I can't figure out exactly how that's done either).
thanks in advance, sure I"ll have some more questions as I go...
