pristic
Guys,
I know and have read the threads related to this however am stuck.
Before I went to the PAMCO I could ride over an hour and it would be fine (I have always had plugs fouling in the past though - to me means running rich) but keep reading.
I installed the PAMCO and things are great, pull the choke, start her up, almost first kick every time. Runs sweet... happy days. However, I took her about 5kms from home, she ran fine, as I got into the underground carpark, she started idling low and wanting to die, a bit of throttle and she was ok... but as soon as I back off the throttle she just stops, no backfire, no pop, just like I turn the key off.
I kick her immediately and she fires right up again... like nothing happened.
I rode home, same thing.
To me its either the coil or the floats.
The coil if its playing up when warm... but somehow dont think thats the prob.
The floats (if too much fuel is getting in, then when cold its fine, likes the fuel) when warm is fouling/flooding. Ill pull the plugs tonight to check.
What else could it be? Could timing cause this problem?
With my timing, its quite retarded on idle... and I cant get it to be advanced to the correct mark on idle... if I turn up the idle, it is better... but doesnt solve my original issue of it stalling.
Its not the vent cap either, I tried to open it to see if that makes and difference but it doesnt.
Any other ideas? I cant get her over to Geoffs for a tune for some time, and I dont ride her often at all...
To add, its a brand new ultimate coil, new wires, new caps, etc. The plugs are BP6ES and NOT iridiums (shouldnt make a difference?)
Im confused as it happened after I put in the PAMCO and e-advancer... with points it was a pig but didnt have this problem. This is the ONLY issue I am having, no other issues... basically, I dont feel confident taking her on a longer ride as I know the first set of lights or traffic I hit will then be a pain... when she is playing up on idle, if I then take off again and sit at speed, its fine, you dont notice anything at all. its ONLY at the lights/traffic etc.
Make any sense?
Cheers,
Peter
Make any sense?
Cheers,
Peter
