Zonie
I am working on a new to me 76 XS650. Been collecting parts and now I'm ready to replace the fork seals.
Removed the axle nut and washer, loosened the cap bolts on the LH leg and hit the axle with a rubber mallet.
Didn't think that would work but worth a try. Next was a bigger hammer and a block of wood, still no go. There is corrosion between the axle and the RH fork leg. Need to get some good penetrating oil as WD-40 is no good. Tried to rotate the axle with no luck. Suggestions?
Zonie
Zonie
