I want a tool like this for the nut on the steering head. Do you call that a clutch nut socket? I measured between cutouts and it's close to 35 mm. Can one of you verify this for me please? Thanks.
Me too. But I have tapered roller bearings in everything I mess with. Easy. My SH has ball bearings and they’re perfect. I also have perfect spares. It’s not so easy to find that sweet spot. They roll fast. The FSM has a torque spec to set them. I assume they’re less likely to brinnel if correctly installed.Personally, I use the two spanner wrenches. You need two so you can hold the bottom nut as you tighten the top one against it and lock them together.
I set it as I would any tapered roller bearings. I gotta say there just isn’t that sweet spot with these. The book gives a torque spec, then back off a quarter turn or something like that. Too bad that socket isn’t listed in the front of the book.My only suggestion when tightening head bearings of any type is as you tighten slowly to torque also slowly rotate the forks back and forth
I'm afraid I find the tapered roller bearings, vs. ball bearings a lot like apples and oranges. Both bearings and both fruit.On the FJR which is a much heavier bike most guys torque them (tapered bearings) a bit over the recommended ball bearing torque. On these smaller bikes I tighten them to the point I need to give a little push on the the handlebars for the wheel to fall side to side when elevated. You can over torque pretty easy which is evident by the weaving you get with the bike as your trying to go straight.
The steering head takes some pretty heavy side loads. Not just in turns but in heavy front brake use too. The tapered rollers do much better with side loads than balls.I'm afraid I find the tapered roller bearings, vs. ball bearings a lot like apples and oranges. Both bearings and both fruit.
Yep! This is mostly, "If it ain't broke, don't fix it." I'm surprised how light the steering feels with the balls. How long will they last. My first one's went a lot of miles with no maintenance. I'd like to see how they do with appropriate servicing.The steering head takes some pretty heavy side loads. Not just in turns but in heavy front brake use too. The tapered rollers do much better with side loads than balls.
That's one reason wheel bearings are tapered rollers and not balls... constant side loading.
... fwiw of course....
