Ok I tried this (Thanks again 2M ). After indexing (really important part of the process) I turned it back and forth a little. Nearly no change. An eighth turn L resulted in a reading of 17.?? volts. An eighth R raised it to 18.9?. Finally worked my way to the stop on the L and it was still 13.?? volts. The other meter reading 12,77. Resorting to chemical assistance I gave it a short shot of electric contact cleaner twisting to and fro. After cleaning I ended up back almost exactly at the index mark with 12.79. Now if you just barely breath on it the reading changes so a bit of luck is required to exactly match to another.
The freebie from Harbor Freight also has this adjustment and it is just as touchy. But in the end I have three meters reading 12.76, 12.77 and 12.79 good nuff.
