So I'm at the wiring stage and I cant figure this out...
I'm using a trailer light converter module so I can use my rear dual filament bulbs as tail/signal/brake lights. All is well except for the signal portion, I've attached a rough drawing of what my wiring set-up is, except im no longer using led lights, just regular dual filament bulbs.
When I put power through the flasher the module wont flash the brights. Except if I tap the flasher it'll work. If I wire the flasher after the module it works fine, so I know the flasher is fine. But that wont work cause I would need 2 flashers, one for each light.
If I wire it up without the flasher it works fine, but obviously the bright just stays on.
So i dont know if the module is messed, or it has something to do with voltage/current draw within the module, anyone have any ideas?? I'm sick of fumbling over this
