Paulrxs650
A little more done today. I finished off the rear master cylinder set up. I machined the aluminium spacers and attached the bracket, I'll get some neater button head M6 bolts to finish it off. I also machined an aluminium extension piece and secured it with an M6 bolt to the lever, by way of a 10mm spacer. To stop it rotating in use I pinned it together with x2 4mm pins. I also had to machine an extension to the master cylinder rod, M8 one end and M6 the other, to take the rod end.
I'm quite pleased with the result.
