Thanks John! Hope you managed to get some done too
I am Carbon - thank you for the comments, much appreciated. Yes. I would like to shake that chap by the hand!
So a little more done today - New 31 tooth sprocket fitted with refurb'd bolts. Fitted the chain, had to take about 10 links out. Got a nice new chrome gear lever too!
Made a little tab bracket up and got the horn mounted.
Made a start on the wiring by making up a green LED in a grommet that locates in the bars to act as a neutral light.
Also thought I would wire the headlight up. Then I discovered what I bought is a bit of a rip! Its a Bates style lamp, with what I thought was dip and main beam, it even had a little blue main beam indicator light on the top! Upon opening the unit up, one wire went to a bulb in the main body as per normal and the other to a bulb who's sole purpose it is to light the blue indicator light! Lesson learned - if its cheap - dont bother.
John, check yours out as I think you may have the same one if I recall.
