Anyone have an issue with this?
I installed this ignition kit on my xs2:
https://www.mikesxs.net/xs-charge-xs650-ultimate-high-output-ignition-system-70-72.html
While troubleshooting some starting issues I took out the plugs, and the right one looked like it had been hit by the cylinder or something. There was a small sliver of metal missing off of the side electrode right at the end and it was also bend down to the point that it was in contact with the center electrode. I honestly wasn't sure if maybe it was dropped or something so I re-gapped the plug and popped it back in. After cranking her over I took the plug back out and it was fouled up a bit but had a fresh scuff on the same spot. From the angle, I am suspecting it's the valve striking it? I can post photos tomorrow if needed, but has anyone ever come across this? I looked in the forums and haven't seen anyone report it.
They are the NGK BPR8EIX Iridium Spark Plugs, which (after checking) are longer than the ones I had in before, but they are the ones everyone seems to be using on here with the PAMCO and dual output coils. Are there spacers that everyone is using?
Thanks for any thoughts,
Holt
Holt
