Just the mothership - the other two were fully disassembled and the Special was just the frame and the motor.
...and THAT is Big Blue!
..complete with Tail of the Dragon sticker on the rear door.
Pics??WOO HOO Machines café handlebars came in the mail today! Wrenches might be spinning tonight!
When it happens. Pics will be taken...Pics??
HHMMMM... grips will be below the Fork tops, so whatever way that is. C'mon they are Café Racer bars! They are made to go on one way! Poor boys clip on bars...Cant wait to see which way they end up ? Right side up or Right side down ?
After the initial proving out ride of 19miles, the 79F got the oil drained & plugs pulled.
Nuttin .. Oil is purdy . Plugs are uneven, one lean & one rich.
Great news! the leaking petcock to tank screw gasket has apparently cured itself.
No real leaks yet even. It just keeps gettin better.. View attachment 138159 Hey AZman, this is the bike those cafe bars came off
Well, selling motorcycles, its a bad habit I have huh ? But ya, that is the plan. Actually going to help fund the 78E real nice. This is actually fun too !Great work Randy! Are you sure you want to sell it?
Sometimes you just have to move forward.Hell of it is I just bought a shinko classic (The Goodyear replica) for 69.00 and free shipping
... a very frustrating and dissapointing exchange with J&P cycles...
and they did spin that night. At the same time a germ also wrenched itself in me and took me down toward the end of installation. It kept me down a couple days and while I'm not 100% back I'm almost there. Here's the promised pics before during and after. I did one last pic with me in the saddle to see how everything fit. I them put the old bars back on. Maybe in the next rebuild I'll use them with rearsets, although it wasn't bad without them.WOO HOO Machines café handlebars came in the mail today! Wrenches might be spinning tonight!
I’m no Guru, (yet) but that def sounds like valve clatter. A little is normal and healthy for these bikes, but you don’t want it too excessive because you could prematurely wear your valve adjuster screws. Yours sounds a little excessive, but you can’t really know until checking your clearances. You can adjust your valves easily enough on your own; it’s not much more complicated than changing out your bars. Shouldn't take more than 45 mins tops, start to finish. There’s a wide range of specs throughout the different years; it’s generally accepted practice to set the intake at .003” and the exhaust at .006”. Give or take a smidge to your preference for how clattery it is. Look up “valve adjustment” with the search function. Make sure to set your cam chain tension first, and set the valve clearances on a COLD engine. Set your timing last. No reason to pay a mechanic you don’t even sound too confident about. Good luck!Replaced the fuel line and added an in-line filter. She's running strong but there sure is a lot of clattering.
After seeing the responses of several of you gurus to another member's post of a video of his xs running, and you offering your observations of what the noises meant, I thought I should post a video of mine. Since I'm no mechanic I have to take mine to an independent to have work done. I never know if what he tells me is correct or not. So, if ya'll could take a listen to this and tell me how bad my problems are I would be really grateful. 2 basic questions:
1. The loud tapping sound in the engine.
2. The two different exhaust sounds - the right one seems to make a puffing sound that the left one doesn't. Left one sounds good to me.
Any help is greatly appreciated.
