What valve setting should I use for my XS2
CalsXS2
XS650 Guru
The more I search, the more answer's I find. I'm running a 76 motor in my 72 bike using the 72 carb's. I read in a post somewhere that you should tune for the year of the carb you use. Would this necessarily be true for the valve's also.
This is copied from a tech article here.
- set tappets - model...inlet...exhaust
...XS1-B.....0.003"(0.076mm)...0.006"(0.15mm)
...XS2-650..0.006"(0.15mm)....0.012"(0.30mm)
...XSB........0.0024"(0.06mm)...0.004"(0.10mm)
...XSC-on...0.0024"(0.06mm)...0.006"(0.15mm)
This is copied from Mike's.
Q. What valve tappet clearance do I use?
A. All Models 1974-84: Inlet: 0.003 inches (0.075mm.) Exhaust: 0.006 inches (0.15mm.)
A. All Models 1970-73: Inlet: 0.006 inches (0.15mm.) Exhaust: 0.012 inches (0.30mm.)
Note: Set valve clearance with cylinder being worked on at top dead center on compression stroke.
What do you guy's recommend. Thanks.
No, that's only in regards to parts inside your carbs. Use specs for the '72 engine when tuning anything in the engine.
