TimeMachine
SeventyEighte
Canadaian rtgman, I think you folk measure mileage in "smiles per litre" ? From what I've seen of your local routes..
You didn't follow the "Leakless XS Assembly" tips that many of us use. Those consist of adding narrow beads of sealer to both sides of the head gasket around the cam chain tunnel, the 4 outside stud holes (the ones that flow oil), and as added insurance, across the front between the outer stud and the cam chain tunnel. Like so .....
The head gasket was installed dry by the factory but that was 30 years ago when the parts were factory fresh and new. Today, a little added insurance to make sure things seal isn't a bad idea. This pic that I "doctored" is from eBay of a new factory head gasket. Note the shiny areas on the gasket at the top and bottom of the cam chain tunnel. That is factory applied sealer so as you can see, a factory gasket came with some sealer in what Yamaha probably figured were critical areas. Note they pretty much correspond to where your untreated gasket gave way.
I questioned that with Smed speed he said the second ring has beveled edges,, is that correct . I beleive one bevel is slightly larger .Simply installing the 2nd scraper ring upside-down can introduce oil pumping like yours...
Hi TimeMachine,Canadaian rtgman, I think you folk measure mileage in "smiles per litre" ? From what I've seen of your local routes..
