I was taking apart my throttle shafts to replace the seals. However upon trying to remove the screws that hold the butterfly in, they stripped. And then to top it off the screw remover drilled itself through the side of the screw destroying the threaded hole. Now I need to replace the rod too. But, I can't find a replacement. Can anyone help me find one?
Do you have a set of bs38 carbs that you would part out? I need it in a hurry!
Thanks for any consideration.
