Your engine sounds normal and sweet, you have no miss fires Don't forget it's firing on 360 and cam timing comes into the factor also as does type of ignition.This is as good as I can get my idle using VM34s, I think the pilots might be a bit small though... if I adjust my idle speed up to 1400rpm its smooth with no misfires... and boring.. rather the odd miss at idle now I've owned the bike for a few months.
I.
My bike is points with a shot advance unit. It has UNI pods, NGK plug caps, and Vance and Hines mufflers on '72 head pipes. Stock jets in BS38's and 26,000mi on the engine.I'm starting to imagine I can tell the difference between TCI and not, from their sound.
