I have a 1982 xs650.
Let me start by saying I don't really know what I am doing and am only basing this work on what mainly INXS has posted (I read it was a composite of many others work...Pamcopete, Jayal, retiredgentleman), so if any of this does not add up please let me know. I apologize for the length of this post. And I really appreciate everyone's effort on this site because without it I would definitely not have a clue as to what I was doing.
I have used the version INXS posted on 10-14-2009, 06:37 AM (tech section wiring diagrams), but I slightly modified it to remove the starter motor, headlight off/on and high-low select switches, front brake switch, and power outlet (I did not know what the power outlet was for). Please see attached diagram.
I assume that INXS version will work and just wanted to ask some questions since some of my wires don't match and I am trying to finish this up so I can get to riding.
Problem #1:
The wires leaving my pick up coil are orange, grey, and black. According to the INXS diagram the wires leaving should be Green-white, Red-white, and black-white. So I don't know how to add these to the ignition unit. Is the black wire the ground for the pickup coil and rotor/stator (I don't have a ground coming from the rotor/stator)?
The wires leaving my ignition unit are white-red, white-black, white-green, black-white, black, red, orange. I would guess that according to the INXS diagram that the pick up coil should be connecting to the white-red, white-black, white-green wires. The red and orange from the ignition unit goes to the ignition coil, and the black goes to ground. I don't know what to do with the black-white leaving the ignition unit.
Problem #2:
The wires leaving my rotor/stator are white, white, white, yellow, and light blue. I know to connect the 3 whites from the rotor/stator to the 3 whites of the rectifier/regulator. I see from INXS diagram that the yellow should be capped. But I don't know what to do with the light blue... cap it also?
Problem #3
The wires leaving my brush assembly are red and green. I know the green from the brush assembly attaches to the green from the regulator/rectifier. But does the red from the brush assembly attach to the brown of the rectifier/regulator?
Thanks for any help
Dave
modified INXS post diagram
from rotor/stator
from ignition unit
from pickup coil
from regulator/rectifier
Problem #1:
Problem #2:
Problem #3
Thanks for any help
Dave
from rotor/stator
from ignition unit
from pickup coil
