Hey everyone,
I am working on my brother's XS650 (I think it is 1981, it is for sure a single reg/rectifier and electronic ignition unit) that is not charging. I'm going through Curly's list and things are getting better. I have a few random questions, though, related to repairing wiring.
First, I am finding holes in the shrink wrap that covers the wire for the positive brush. They are small, but enough that I can find them with the multitester. They are right at the point where the wire crosses the screw that secures the brush holder to the stator. This screw goes to the stator, and is therefore grounded, so I believe that they are causing random main fuse pops. I have a few layers of electrical tape wrapped around it, but is there a better way to fix the heat shrink?
My 2nd question is also stator related. Following the wire where the stator connects to the main wiring harness, the spade connectors on the white (well, black on my stator because it appears to be an aftermarket replacement, but white on the bike's plug) wires are pretty bad. Does anyone know the correct size so I can hit up a nearby auto parts store replace the connectors? I have them out of the plug, so I think I can crimp new connectors on, shrink wrap them a little bit, and stick them back in the plug.
If I get a chance, I'll post some pics of the carnage. One wire was completely broken off and the plug was melted a little bit from the other wires trying to carry the current. It looks like my brother was close to a fire before I started checking things out. Stator seems to test good with the meter though, so I'll try connectors first if anyone knows the size.
