XS1B indicators - another dumb question
Grewth
UK
Can someone please clarify the difference between the front and rear indicators that should be fitted to my XS1B ?
I'm sort of getting conflicting information from different sources.
The two rear (?) items I've got have had the innards and wiring stripped out but have a solid 8mm mount stud.
Can't see how the wire could run through the solid mount collar.
There are also illustrations with a hollow mount stud with the wire passing through its centre.
I forgot to ask.
Are the indicators externally the same size, front to rear ?
The supposed rears I have are approximately 125mm long from the mount face.
Ahhh.
Thanks for that.
That's opened up a can of worms.
My parts catalogue totally contradicts that, but it's probably for a different market as it covers XS1, XS1F, XS2.
According to my parts book, only the '70 XS1 model has that type of fender stay (256-21645-00), the XS1F and XS2 have the later type (256-21645-01) with different indicator mounts.
My XS1B (North American market AFAIK) also has the late type fender stay along with the round type tail lamp.
So I think I need indicators with hollow mount studs
Sorry, this is the stay I have fitted
Sorry, I don't know if I'm helping or hurting; my book appears genuine, but it is a PDF internet thing. Perhaps an actual expert will happen along and clear this up.
More or less random shots of XS1B 's that have passed through here, or I had saved for whatever reason.
So, this "book" that I have also shows the "octagon with a circle" small taillight for XS1, round for XS1B and XS2 - and that matches my memory.
No, you're definately helping.
Many thanks.
I'm quite confident now that I don't need the "solid stud/side wire" type indicators at the rear.
In fact my favoured UK supplier (Yambits) lists front indicators and rear indicators as separate items, but if I'd bothered to look at the product code, it's actually the same item.
