Why can't someone with all this tech and knowledge just produce an aluminum pushrod that fits the years of Xs650 s?New 1-piece clutch pushrods have been found to have these dimensions:
Diameter = 0.315" (8mm), but 5/16" (0.3125) will work fine
Length = 9.570" (243 mm)
Outboard/worm end has reduced diameter of 0.262" - 0.267" (7mm)
This reduced diameter is 0.300" - 0.325" (8 mm) long
Received a new MikesXS clutch pushrod. Inspection revealed that the ends are rough, the body is mill-ground, not polished, and rolling it on a flat plate shows that the rod is slightly bent. I'll straighten it, redress the ends, and polish the whole surface.
Pic #1 - Small-end, my polished/dimpled rod on left, new MikesXS on right.
Pic #2 - Clutchpack end, my polished/dimpled rod on left, new MikesXS on right, very rough.
And why are there parts out there that no thought has gone into like the heat differential in materials. Might as well buy from a Chinese site. You'll likely get the same, if not better product quality.
