sometimesnever
Hey guys,
My brother and I recently finished the very long build of my '81 XS650SH down here in Aus and I'm now trying to get it running reliably so that I can actually start riding it!
A bit of background first:
The bike when we bought it was in good running condition and 100% stock.
During the build, we fitted a Pamco (E-advance), Mikes/HHB PMA kit with the dual output coil, deleted the battery with a Sparx cap and removed the starter gears, so kick only and rewired from scratch.
It also has Unifilters and a set of Gordon Scott "fat chopper pipes".
Timing and valve clearances were set during the build but carbs at this stage were untouched from stock.
The problems:
After initial assembly and wiring, the bike was a bit difficult to start. On the somewhat dubious(?) advice of a friend and reading some threads on here, I swapped the BP7ES plugs for the hotter, resistor type BPR6ES and that actually made it start much easier.
After doing some light test runs in the streets around my house, I found it was stumbling off idle (sometimes stalling) and breaking down for a second here and there but pulling pretty well through the rev range (restricted to 2nd and 3rd gear and max 60km/h due to inner city streets).
The real problems start when it gets hot...
The idle starts hanging quite high, getting progressively worse the longer I ride (within 10-15mins). Engaging the clutch brings it back down temporarily but it hangs again soon after taking off.
Once this starts happening, if I shut it off (or it dies) it is impossible to start! Even after waiting 30 mins+ it won't start (also tried using starter spray) and after wearing my leg out, I've been putting it away and leaving it until the next day, when it starts second or third kick.
I assumed the bike would probably be running lean due to changing the pods/exhaust and some advice on here that a lean condition could lead to hanging idle. However every time I have pulled the plugs (often during testing), they have had wet black deposits around the circular outside edge. This black wet stuff wipes off pretty easily with a rag or finger and isn't what you would call "sooty", more like "tacky". Electrode looks light brown and relatively normal (?), if a little uneven in it's colouring.
Things I've tried:
- I checked carb balance with the manometer method and they were out of sync. I got them balanced.
- Set the mixture screws 3 turns out (and various half/quarters turn adjustments either side of that, when the bike was running).
- Pulled the carbs, checked for jet obstructions and general cleanliness, set the float heights (which were out of spec). Inspected the diaphragms and tested for leaks by blocking the vent.
- Replaced the cracked old intake boots and gaskets.
None of this has yielded any noticeable improvement... So my quest continues but from here on out, I'm not sure exactly what to check/adjust next and in which order of priority.
I have a timing light on the way to check that. I also assume valve clearances will be a good place to start, even though they were set when we put the engine back together?
I'm also very happy to revisit the carbs as I really only did the stuff listed above, hoping that would fix things.
Other than that, I'm not sure what to do next.
Any advice would be greatly appreciated!! I love the way this bike has turned out and if I can get it running properly I will be a very happy camper.
Sorry for the wall of text. Just wanted to be thorough straight off the bat, hoping that one of the experts here will see the big picture clearer than I currently do.
TLDR Version: The bike runs sort of ok but won't start when it's hot. Like at all. What should I check and in what order?
The problems:
Things I've tried:
