jurob
Removed the factory harness, using the simple diagram from this site.
Wire that goes from reg/req goes to the battery with an inline fuse. Diagram shows a 20 amp for the main fuse, my keyed ignition switch is rated up to 15 amps.
Will a 15 amp main fuse work instead of the 20?
This is the red wire that goes from the reg/req to the battery and also splits from that wire to my keyed ignition swith than to my fuse block.
