pregrid
XS650 Guru
You may have to re-think that 1" drop on the fork tubes. Upon full fork compression, the lowers may hit the lower tree. If I recall correctly, there's only about 3/4" of space when the forks compress fully, and that's with no dust cover. Pull the spring and slide the lower all the way up, you'll see what I mean. I usually do a 3/8" drop.
Good point, did not consider that (rookie builder doncha know). I'll def check that. Thanks.
