connor1
Troubleshooting a carb problem on BS38s on a tx frame. Right side carb won't idle steady and stumbles if revved. Took carb off for cleaning the pilot circuit and noticed the slide falls way fast 2 to 3 seconds to bottom out when thumb is over the oval port on top the Venturi.
I have a set of xs2 carbs that I rebuilt and the slide falls in about 10 seconds. So I decided to swap the slides thinking that the diaphragm was no good.
As you can probably guess the "bad" slide worked fine In the xs2 carb body and the "good" slide fell quickly in the carb body I am trying to fix. Yes the choke was closed.
anyone know why this might happen? What will the effect be on peformance if the carb with the quickly falling slide is put back on?
I would swap the carb sets but the choke is a different setup that will cause some other issues...
