Bob Kelly III
Ranch Kid from way back,.... that got Old !
In another Thread a fellow member whom I have allot or respect for maintains that the carb floats are not meant to be a shut-off valve for the gas....
and I totally disagree.... that is what they were meant to accomplish, and if their not accomplishing that task their not set correctly .... to me it's very straight forward....
However I would like to hear More Opinions on "the theory of Operation" of the floats in your carburetors ! .....
if you agree or disagree with My view I would like to hear it....
and a description as why you think that way would of course add to the validity of your idea.
I found that setting the floats BY THE BOOK failed to stop the flow of fuel through the carbs....( with a full tank of gas) , I had to re-set them Just a bit, to get them to stop the flow completely.... perhaps this is the reason this theory has started, ... setting them by the book doesn't work perhaps ????
..... in every carburetor I have ever worked on the function of the float and float needle Is to shut off the flow of fuel completely.... not just partially..... Completely it this was not the case then you would have gas escaping the carb in an Over flow condition.... not what any of the manufacturers intend I am sure!
the only thing I can think that would confuse the idea is the fact that they put a petcock before the float bowl so you can turn the fuel off, after all you don't have that in a 1970's era car or truck why do you have one on a motorcycle ?
My answer to that is that the car or truck are fuel pump fed at a fairly constant pressure and the floats can be set to shut them off very well and when the motor isn't running the gas isn't trying to push the floats down.... that is not true on a motorcycle, when a bike is setting with the fuel on the entire weight of the gas is setting on the float needle in the form of pressure all the time 24/7
however that pressure is relitively small, BUT it is still there, so as a safety precaution they put a on off valve to stop that pressure ......Just incase one of the floats stick open which they are prone to do
in any carburetor because of impurities in the gas. and with a motorcycle you can park it in a very un level angle too... which can aggravate the situation...... on the side stand on a steep hill for instance.
....So I maintain that the Reasoning of the Float and float needle is to shut off the fuel flow completely.... not partially , as fuel would still leak out causing a danger.
Let us Increase our Knowledge here shall we ? shed some light on the subject and maybe we will all come out smarter in the end !.... I hope to anyway ! <GRIN>
Please add your comments !
Bob..........
Bob..........
