alexml
Hi
I managed to put together a mix n' match PMA system using a RD250 stator and backing plate, with a really nice adapter plate made by COFA engineering. What I am wondering is, should the RD400 flywheel that I have fit. When I fitted it up just to check it seemed okay, but now I am putting it together for real i wanted to check. It goes onto the crankshaft taper okay without a woodruff key, but stops about 10mm short of where the standard flywheel reached. With the woodruff key in place it only reaches about 15mm from where the original flywheel reached. I am wondering now if the taper on the 250/400 air cooled flywheel is correct. I don't remember where I saw that the 250/400 flywheel fits so cannot check. We don't have many Banshees hear in the u.k so I am assuming that the RD 350 YPVS is the same flywheel. Does anyone have an idea of which flywheels fit.
Thanks
Thanks
