tigs79
HI there guys,
Need help, battery not charging, i have a 7 wire rectifier from mikesxs connected,
it run fine then it stopped charging , i tested rotor 5ohms, the stator between the white wires I get .4 ohm. I took the exact same rectifier from another bike that was working and fitted it same results. when the motor is running higher revs it seems to charge the battery a little 0.01 0.02 instead of draining it. Lastly i never unearthed the one brush and the bike worked fine till now, only now i was told to do so and did it, only after it stopped charging earthed it again thinking that could be part of the cause but no results
I'm at a point with out many solutions that I can think of, maybe you can help.
also when motor is running not getting alternating current between the white stator wires
Thanks
Thanks
