I've seen the thread on adapting aftermarket mufflers to the stock double-walled headpipes and plan to do just that.
The picture shows my stock headpipes with the mufflers cut off. This leaves me with questions:
1. Should I cut the outer pipe further up towards the head? I'd prefer not to leave that fuggly boss where the outer pipe ends.
2. If I can't/shouldn't cut the pipe higher up to get rid of that, what's the suggested technique for covering it?
3. Should I cut the inner pipe shorter? It runs up inside the new mufflers just fine. I can a) leave it as is as long as it clears the baffles in the muffler; b) cut just enough off to clear the baffles if there's a problem, or; c) cut most of it off leaving enough to clamp the adapter and new mufflers to.
