ihaxs650
My stock 1980 Yamaha XS650 special is getting more than 6 times the amount of HC in the right cylinder vs the left cylinder. I am getting a popping at idle and on deceleration from the right cylinder only. I believe this is causing the right cylinder to operate at a higher temperature than normal. I am looking at a clutch drag issue when hot and I believe engine temperature is part of the problem.
The 1st picture is the right cylinder at idle. Notice the HC at 4023 ppm.
The 2 picture is of the left cylinder at idle.
Notice the HC at 666 ppm. At 3000 rpm the HC is relatively the same for both cylinders, I am using the left cylinder as the baseline and I interpret the right cylinder has a lean-misfire. Most likely too much air.
Here are the numbers from my FT500 Ascot a thumper.
Notice the CO number of around 9%. This mixture was achieved with a jetting kit from Thumper Stuff. This upgrade was an absolute must for the thumper.
My goal is to resolve the popping issue from the right cylinder " the lean-misfire'" and than fix the co issue as I believe they are separate issues.
I would appreciate any comments or help in the popping from the right cylinder. The bike seems to idle just fine besides the popping but my hearing is not that good. I have not started any other diagnostics.
