alfredo
1978 xs650 Special
I have a bunch of questions about this coil as I think mine is blown. Was running just fine cruising down the road then clunk. Was only running on one cylinder. I pulled the plug wire from the left side and the bike ran the exact same. So, that told me it was dead. Friend tried to test the spark by sticking a screw driver inside the plug cap while the motor was running to see if it would ground to the block.....no spark. I looked at all the wiring and the fuses and all was good. No blown fuses or loose wires.
So I am down to two things, the spark plug wire or the coil. Rather than wait and not figure it out, I want to try and get a replacement coil ASAP. Run this weekend that I wouldn't mind making and having a backup coil isn't a terrible thing if I find out its something else.
- Where can I buy a replacement and have it shipped ASAP? (Mikes doesn't seem to sell singles and looking to go on a run sooner than later)
- Is there another coil that is the same shape/output that I could replace the green monster with? (possibly available online)
- Best way to test these coils with a crappy harbor freight multimeter?
