mcarrel44
Padawan Learner
Hello
I am working on my first build and have encountered my first problem, I'm hoping someone can help me out. First let me post some pics of what I've done so far.
The problem I am having is that the shock can't support the weight of the bike. It is off an '08 Yamaha R6, which has a linkage system to reduce the leverage the swingarm puts on the shock. When I take it off the stand the bike nearly rest on the floor and the shock travel is real mushy for lack of a better term. I know that when monoshocks first came out they didn't have the linkage system on them but they were mounted differently so they acted on the swingarm closer to the axle. Any suggestions as to maybe a different shock I could use, or would it be possible to respring this shock with something stiffer, it would have to be in the 30kg/mm (about three times the 10.5kg/mm it is now) range to counter the swing arm leverage. If I could find a spring with that rate would it mess up the damping action of the shock. I could build a linkage setup, but I like how clean the rear end looks without a bunch of bits and pieces back there. I also included some pics of the swingarm modification, and the lower shock mount.
Any help would be greatly appreciated.
Thanks,
Matt
Thanks,
Matt
