visimpact
I have a 80 Im finishing up right now. I have a oil leak that Im trying to find where its originating. I thought maybe it was coming from the counter shaft seal or the shift seal. I have replaced the shift seal. I also replaced the sump gasket and the starter gasket as well. I came in after a ride the other day and there was a significant amount of oil under the bike the next morning. I was thinking maybe the counter shaft seal or the shift seal didnt seat right or got ripped(NOT THE CASE). I took the cover off and I bent back the washer holding the nut on the front sproket and did notice that the nut was not tight. From what I have read this should be torqued to 80ft lbs? Can someone confirm that? Anyway I took off the sproket and inspected the seal. It looks to be fine and I didnt see any excess oil leaking anywhere. I did notice when I pulled the side cover off most of the oil was right under the stator dripping on to the top of the kickstand area and sitting right around where the wires go thru the rubber bushing. What is leaking here? Is the countershaft nut not being torqued properly the issue?
Oh and I also put everything back to together and cleaned it all up and took it for another ride. After I got back most of the drips and oil where over the kickstand area again and the shift seal was dry and the countershaft looked pretty clean as well. Thanks for any help you guys can give me.
If pics would help I can shoot some later tonight.
