Fred, yeah, this is a messy arena. A lot of that has to do with base metals and immersion time. I've had Aqua Regia on my fingers (pH less than 1), then quickly rinsed and neutralized with no ill effects. Same with strong caustics. But, give them a few minutes..........!!!!
I've used pine sol on my BS38s, in an ultrasonic cleaner. It was ok removing some fuel deposits, ineffective on others, including that 'zinc rust'.
I think what we've got here is a challenging combination of:
Things that you want cleaned, and not damaged:
- Carb parts materials (zinc, aluminum, brass, rubber-type seals, gaskets, nylon, ...etc)
Things that you want removed:
- Fuel related deposits, complicated by gasohol and additives
- Non-fuel related deposits (tank sealers, fibreglass, sugar, children's toys)
- Surface corrosion residues, from carb metals and such (like that white zinc rust)
Things available for cleaning:
- Cleaning solvents, with various properties, and various compositions
--- Polar and non-polar
--- Acidic, neutral, caustic
--- Organic (hydrocarbons) and inorganic (acids, salts, bases)
----- Various organic types (chain, cyclic, ...etc)
Cleaning procedures and guides:
- Time, Temperature, Agitation
- Then add the obscure rules, like trichlor on aluminum
Lotta combinations here, and I'm sure there's more. Whatta mess.
As much as I like experimentation and testimonials, I'd rather have some kind of chart, identify problem -> solutions.
Or, a magic elixir that fixes everything (*har-har*)
But, for the most part, I've been playing it safe using off-the-shelf like you, including the Berryman's dip...
