Ok, as gggGary said the rotor is 5.6 ohms. it will work as low as about 4.5 up to about 7 ohms.
The stator is .9 ohms. White wire to white wire, check the three as three sets of two.
When performing tests on such low ohm items set your meter on the lowest ohm scale. Touch the probes together and remember this reading. It is the ohms of the leads.
You need to subtract this reading from the test reading to get the actual ohms.
As In touch the probes and get .6 ohms. Do the test and get 5.9 ohms. do the math, 5.9 ohms - .6 ohms = 5.3 ohms. Your meter will read whatever it reads. I have one that reads about.7 ohms, the other about .1 ohms.
Read the charging guide it will give you step by step how to test.
