Growl
XSJohn experimented a lot... and shared his experiences... I decided to try one of his suggestions "gear it tall but retard the timing"
I tried the stock 17/34 USA gearing for a couple years, but it wasn't pleasant for freeway cruising. Then, I really enjoyed running a 30 tooth sprocket for years. When I scramblerized the bike, I thought 38 teeth would be the ticket for dual sport... but just couldn't get into it. What a grind! So I installed the 17/33 Eurpean gearing which is pretty all round usable.
Then I retarded the timing by 2 degrees, as XSJohn suggested. It works! You do lose acceleration... the engine is less fierce. Mellower. But able to run at lower rpms without lugging. It now is smoother at 9 mph that it was at 12 mph. It is easier to plod along. As a bonus, the bike is also a bit smoother at freeway speeds... It is running cooler according to infra red thermometer readings. I will be tracking MPG.
