Simplified electrical schematic.
toglhot
First class butcher.
Adelaide
I don't normally draw schematics, I just work them out as I go. But, this is roughly the schematic I'll be following. I'm doing two harnesses, one for ignition and one for lighting. Just makes it easier for fault finding and does away with one huge bundle of wires. There are five wires in the lighting harness and three in the ignition harness. I've done away with the neutral light and a few other bits and pieces I considered unnecessary. I could only get certain colours from the local auto accessory shop, but I managed to keep it reasonably close to the switch gear colours, but of course blue with a white stripe, yellow with a red stripe and so on aren't available, so I've substituted plain colours where necessary. These don't coincide with the front/rear indicator and tail light cable colours, but I can live with that. It's set out in the sequence the bits and pieces are mounted on the TX. There's probably one or two mistakes, but I doubt I'll be following it to the letter.
