Sold / Found / Inactive - Spedo Rubber and special washers
BowlingSS
XS650 Guru
XS650.com Supporter
Lawrenceville, GA
I have a spedo for my GS650 that will be here soon and I need the rubber mount and the two special washers.
Search eBay using the part numbers for the washers, they are readily available.
For the damper, you may have to adapt a tach damper, which is very similar, again, search eBay using the tach damper part number. When you do, some AS3 and CS3 dampers will also show up, they may work better.
