smokinjoefission
Hi All,
first, I'm a long time lurker but this is my first post, greets!
I've got an '81 XS650H and am diagnosing a weak charging system. The old battery would let me ride for about 15 mins before the engine would just die. A brand new Yuasa seems to let me go for at least 1/2 hour, but a fresh charge goes from 12.5 volts to 11.9 volts during that period.
Voltage at 2500 rpm seems to be ok at around 14 volts but the battery just doesn't seem to charge from the alternator.
Going through the book and what I've read online, I've checked out/tested the brushes (14.5mm long, both), regulator/rectifier (no short circuits, no open paths), alternator coil (it magnetizes when the ignition is on) and now the stator.
Right off, it shows 1.3 ohms of resistance (brushes removed) where the manual says 5 - 7 ohms.
Soooo ... is it time for a new stator? If so, where's the best place to get it from?
Thanks in advance,
SJF
Thanks in advance,
SJF
