I've read several thoughts about this screw and seen it called several things. So what does it do?
How important is its setting?
I don't think it affects much except idle. When the throttle plate opens a little the holes behind in come into play.So what does it do?
Don't call me Shirley. With the throttle plate closed it's close to 100% but with the throttle wide open I think the effect of it's setting would be small. Pilot jet size would have more of an effect because it effects all the little holes. I've seen people equating a couple extra turns out with an increase in jet size but I don't think that's quite right except at idle. No carb expert at all here, just saying what seems obvious to me.OK xjwmx but it doesn't close so shirley it affects the hole range?
================================================================I don't think it affects much except idle. When the throttle plate opens a little the holes behind in come into play.
Good man Pete ! THANK YOU ! did you know that 99% of ALL motorcycle fatalities involve the rider having too much to drink ?I can't wait till I can go for a test ride tomorrow (I've had a bit of wine tonight, so no riding for me).
