RPC3
1978 Standard, stock BS38 carbs, stock air filters.
Looking for some input to see if there's anything else I'm missing before either living with my carbs with a higher than prescribed idle or trying again with another set of carbs. I've fully rebuilt my carbs twice; blown out ever port and passage with cleaner and compressed air, new jets, new carb boots, everything. Bike has a PAMCO with the e-advance and really runs great, except after two attempts, my throttle shaft seals still leak (OEM Yamaha, not mikes). Its mostly the shaft seal closest to the throttle cable, but spritzing some starter fluid bogs the engine on the other carb as well (either carb will bog when the shafts are sprayed). Even with the leak, I can get the bike to idle pretty well at around 1,500rpm and have it be reliable. I can get the bike to idle evenly at 1,000-1,2000 for a while, but if I keep it there on a ride it'll inevitably want to stall out on me a stop somewhere along my ride. Bike really does ride great off idle, no real flat spots, everything else is tuned well.
So I've got two choices - live with having the idle turned up a tick and a slight throttle shaft leak which I might be running a little rich to compensate for, or rebuild another set of bs38's and hope this set gets it done. I do have a second set of bs38's hanging around, I'm just balking at the $50 in parts, time and labor it'll take me to rebuild, balance, sync, tune, etc. I'm 99% sure I did the seals right (its why I took the carbs apart a second time to verify - the seals are facing the correct direction etc). Anything else I'm missing here? I'm pretty confident I don't have a leak anywhere else other than the throttle shafts. I have no clue what the origin of the carbs are, but I thought they were stock (they had the stock 78 jets in them when I opened them up the first time) and its a New England bike, so not subject to the dust and grit of the southwest, but who knows....the leak is there regardless of origin.
What would you do if these were your carbs? Ride it and forget about the leak? Rebuild the spare set of bs38s? Something else?
Thanks!
Thanks!
