robtattoo
Someone said there'd be cookies???
I'm thinking my carbs are overflowing, running through the inlet valve & leaking into the sump
I noticed a gassy-oily puddle a couple of weeks ago (she's been stood for a few weeks) and last Saturday decided to go for a ride, see if I could blow off the cobwebs. She started up fine enough, but idle was a lot lower than it normally is. I put that down to inactivity & the cold. I managed 2½ miles before she started to sputter. I kept her running & turned round, got home & as soon as I pulled the clutch to stop, she died on me. Left a pretty hefty oil trail leading into the car port.
I haven't had the chance or motivation to do anything since, but I'm really, really hoping I haven't blown the crank or output shaft seal!
I'm actually dreading starting the diagnosis.....
