XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 08-07-2011, 08:16 PM   #1
C-Los SD
C-Los SD's Avatar
Default My rephased Cafe Racer build is complete
Finally finished my 77 rephased cafe racer.
This is what it looked like when I bought it last year. These pictures are in random order, I should have did a better job of documenting my build.
I cut off the rear loop and made a battery and electronics tray.
700cc JE Pistons
Freshly painted frame...single stage
Battery tray and solenoid. The Shorai Battery easily turns the motor over
I don't like how this looks, but it I couldn't think of a cleaner way of a fuse block
The coil brackets from Joker Machine work great
Almost there
Home made rearset brackets
Final product
Here is what is sounds like
http://www.youtube.com/watch?v=7joU_9ZE6Zc
I'm getting a lot of noise from the head area. I hope I just need a valve adjustment and it's not something serious. Anyone have any thought on the noise?
C-Los SD is offline   Reply With Quote
Old 08-07-2011, 08:26 PM   #2
azman857
XS650 Junkie
azman857's Avatar
Default Re: My rephased Cafe Racer build is complete
Thats Niiice! I likey!
I don't have a plan and I'm sticking to it! '80 SG with CND needles (#4 slot)and jet, #45 pilot and 135 mains. Ditched the buckhorns and installed bars with wider grips. Stainless steel brake lines, Dual front disc brake, Radio Shack/Chrysler Rectifier Regulator. AGM battery. Pamco ignition with ultimate coil. More changes in progress
azman857 is offline   Reply With Quote
Old 08-07-2011, 08:26 PM   #3
Greg-NWO
Greg-NWO's Avatar
Wow!! That is really, really nice!!!
Where did you get those velocity stacks?
Amazing job! Top notch!
Greg-NWO is offline   Reply With Quote
Old 08-07-2011, 08:38 PM   #4
TeeCat
One-Mik Wonder
TeeCat's Avatar
VERY nice!!!!
TC
1973 Yamaha TX650 single-carb Mild Cafe Roadster
TeeCat is offline   Reply With Quote
Old 08-07-2011, 08:46 PM   #5
tonyc
XS650 Junkie
tonyc's Avatar
That is superior work. Beautiful bike. Enjoy.
1978 Stahdard
1976 standard
1963 BSA A-65
tonyc is offline   Reply With Quote
Old 08-07-2011, 08:50 PM   #6
C-Los SD
C-Los SD's Avatar
Forgot to list the mods.
Hugh's rephased 277 crank and cam
JE 700cc piston
Pamco Ignition
PMA swap
Mikuni VM34 carbs
Steel Dragon Performace V-stacks
Redwing Hammerhead Shocks
Race Tech cartridge emulators...these work great
Happy Dan's Brembo caliper bracket
Brembo Monster caliper
Honda CB750 master cylinder
XS750 Gas tank with Monza Gas cap
Airtech Streamline bubble tail
Motolanna triple clamp
Magura clip-ons
Lots of polishing
Old 08-07-2011, 08:56 PM   #7
retiredgentleman
XS650 Guru
retiredgentleman's Avatar
First class workmanship.....................well done
Noise....................check that your camshaft chain tension adjuster has the "damper" washer.
78SE, Pamco Ignition with E-advancer and Accel #140403S Coil, dual bridge rectifiers, VR-115 regulator, LED tail/brake, BS38 carbs, OEM air boxes, OEM manifolds, OEM exhaust, Heiden Oil filter/cooler, 17/33 gearing, analog voltmeter, Brembo 4 piston calipers front and rear, "All Balls" roller steering bearings
retiredgentleman is offline   Reply With Quote
Old 08-07-2011, 09:08 PM   #8
hmusket
hmusket's Avatar
Too good looking to ride! Put it under a glass cube in the living room.
hmusket is offline   Reply With Quote
Old 08-07-2011, 09:21 PM   #9
CDNTX650
XS650 Guru
CDNTX650's Avatar
real nice work man. show worthy forsure.
2010 Kawasaki Versys
1974 TX650A resto modded and done.
1978 KZ650 b1. Darn near stock, no restore.
CDNTX650 is offline   Reply With Quote
Old 08-07-2011, 10:06 PM   #10
C-Los SD
C-Los SD's Avatar
Old 08-07-2011, 10:08 PM   #11
C-Los SD
C-Los SD's Avatar
I'll check the damper, what does it look like? can't really tell from the parts manual picture...is it rubber? I have that planishing hammer sound effect that goes up with engine revs. Hopefully that is my problem. Thanks!
Old 08-07-2011, 10:31 PM   #12
Ironsled77
XS650 GRAND HACK
Ironsled77's Avatar
Saaaaaaaweet!!
Posted via Mobile
Ironsled77 is offline   Reply With Quote
Old 08-07-2011, 10:35 PM   #13
jamesgs4
XS650 Guru
jamesgs4's Avatar
Very nice! so fresh and clean!
jamesgs4 is offline   Reply With Quote
Old 08-07-2011, 10:56 PM   #14
retiredgentleman
XS650 Guru
Quote:
The damper was missing from my bike. I found an old copper washer in my spare parts and drilled the centre hole slightly larger......................... it quieted my engine. I believe Mikesxs sells one that has rubber in it.
Where did you buy the Brembo caliper, and is that an OEM brake disk?
Old 08-08-2011, 01:32 AM   #15
jay760
XS650 Junkie
jay760's Avatar
What compression are those pistons? unusual to see over size pistons with no flat lip around the edge, I've got a set of 78mm in mine with a lip around the edge, would have thought they might have hit the head, what head gasket did you use? Hoos says to use standard.
jay760 is offline   Reply With Quote
Old 08-08-2011, 05:15 AM   #16
thrashin
thrashin's Avatar
that is soooo purdy.
thrashin is offline   Reply With Quote
Old 08-08-2011, 05:27 AM   #17
xsPete
xsPete's Avatar
700cc JE Pistons
Almost there
Final product
You gotta be proud of that, the attention to detail is brilliant, enjoy it
Hope I finish while I can still kick it
xsPete is offline   Reply With Quote
Old 08-08-2011, 05:36 AM   #18
irristeve
Grow old disgracfully
irristeve's Avatar
very very very nice indeed, sex on wheels,how much drama is involved in fitting 750 tank & how much does it hold,hope its restored to be ridden & not hidden,very good result
irristeve is offline   Reply With Quote
Old 08-08-2011, 05:47 AM   #19
Shiffty
Jim Wilson
Shiffty's Avatar
Very nice job.
Shiffty is offline   Reply With Quote
Old 08-08-2011, 06:01 AM   #20
scott s
scott s's Avatar
Have you tried just adjusting the valves and cam chain? After a fresh build/rebuild, it takes a bit for things to "take a set". I had to do it on my '75 right after the initial start up, even though it had been done on the bench.
Also, plan on doing it again at about 500-600 miles and re-torque the head.
Now...the bike is beautiful! The only thing I would change is the tuning fork emblem on the tank; it's just a little small, IMHO.
Is that one of the early '74-76 master cylinders? How does it work with the Brembo caliper? I'm having some soft brake issues with mine with stock caliper.
How do you like those grips? I just got a set for my CB500 but haven't installed them yet.
scott s is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
'75 Cafe Racer Build gps2 The Garage 19 07-26-2011 12:23 AM
1977 650D Cafe-ish Build Complete, well mostly pa23driver The Garage 5 04-04-2011 09:17 AM
For Sale - 82 xs 400 cafe racer sickbikers Classifieds 6 03-13-2011 12:23 AM
My first Cafe Racer 77650 The Garage 10 05-10-2010 04:21 PM
cafe racer inxs The Garage 11 12-29-2009 01:10 PM
Tags
cafe rephased
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
