oz650
Well done! Where did you get that braided hose to cover the wiring? I've been looking for something like that - it's a great way to clean it up. The Snake Skin looks good too.
The damper was missing from my bike. I found an old copper washer in my spare parts and drilled the centre hole slightly larger......................... it quieted my engine. I believe Mikesxs sells one that has rubber in it.
Where did you buy the Brembo caliper, and is that an OEM brake disk?
What compression are those pistons? unusual to see over size pistons with no flat lip around the edge, I've got a set of 78mm in mine with a lip around the edge, would have thought they might have hit the head, what head gasket did you use? Hoos says to use standard.
very very very nice indeed, sex on wheels,how much drama is involved in fitting 750 tank & how much does it hold,hope its restored to be ridden & not hidden,very good result
Have you tried just adjusting the valves and cam chain? After a fresh build/rebuild, it takes a bit for things to "take a set". I had to do it on my '75 right after the initial start up, even though it had been done on the bench.
Also, plan on doing it again at about 500-600 miles and re-torque the head.
Now...the bike is beautiful! The only thing I would change is the tuning fork emblem on the tank; it's just a little small, IMHO.
Is that one of the early '74-76 master cylinders? How does it work with the Brembo caliper? I'm having some soft brake issues with mine with stock caliper.
How do you like those grips? I just got a set for my CB500 but haven't installed them yet.
Which Airtech tail is that? I've been looking at them and I'm trying to figure out what will work for what I have in mind. How is the quality of the tail? How did you upholster it?
That is the cleanest motor I have ever seen. How did you do it? I want mine that clean and I don't want it to take me all winter. Please tell.
