Zombie Yamaha
Hello guys bought a 1980 Yamaha xs650 a few months ago as and have been getting her in shape for summer. The bike leaked oil from the left side cover when I purchased it so I did some research and found that the clutch rod seal was a popular culprit. The bike only leaks when it has been ran recently or even if I push the bike(while cold and off) in the garage it will start a new little puddle oil also runs down the kickstand. I replaced the seal and used the old style rod because I had read that finding neutral would be easier and shifting would be smoother. Really liked the single rod compared to the previous ones but the oil leak was still there. So then I took the cover off again and it looked like oil had been coming from the sprocket. Replaced the sprocket seal and still leaks! Took the cover off again today to have a look and it seems that inside the actual sprocket (see pictures) is leaking! Is this something that I can repair without splitting the case? I am new to motorcycles as this is my first one so any help would be greatly appreciated!
Thanks!
To get an idea of where the oil lands on the ground two small puddles but most of the time the puddle is double in size. This puddle is from pushing the bike while cold and not running in my garage.
Thanks!
