Getting ready to reassemble my engine (including the crankcases) and I'm a bit confused because I've had some conflicting advice.
Should I or shouldn't I use threadlock / locktite on any of the bolts and screws? If so which ones do you use them on?
If not should I use anti seize on them? Or only on the ones I've replaced with stainless? Again, which ones?
I'm pretty sure the haynes manual recommends locktite on certain things and says not to use any form of lubricant which goes against other things I've heard.
I've been told for example to use loctite on my oil pump housing bolts, and to get rid of the washers. What are your thoughts? (ps, my original cross headed bolts are shot so I'm hoping to replace them.
Hope someone can help clarify this all. Cheers!
