Parts referenced on your schematic:
24-2652 - 70-84 rotor, you'll want to ensure that your old rotor is the same, or be able to accomodate any differences. If the magnet was added to your rotor, you may be able to adapt by adjusting the pickup position.
24-2656 - 80-up alternator housing and stator, OK if your pickup unit will transfer over (don't know if your pickup unit is an actual Yamaha XS650 unit), else need to add screw holes for it or use your old housing. Comes with brushes. Brush holder isn't included with this.
35-0040 - Rotor puller - Yep, get this.
24-8084 - Brush holder, 70-84, out-of-stock. You'll need this, plus the screws.
24-2087 - Combo regulator/rectifier, 80-84. You'll need to configure the brush block for power on the inside brush, outside brush will be grounded by this regulator.
