Hi George and congratulations on the first start.
The video seemed to show the headlight being on before the engine fired.
Did you turn it on or did it light up when you turned the key on or when you hooked up the battery?
I did notice that the headlight brightened with revs which shows that the alternator is working.
But the headlight staying on regardless ain't good and will suck your battery flat real quick.
Hopefully your battery will be OK after it's recharged.
What I'd recommend for test and static run use is to connect your bike's electrics to a car battery
via jumper cables.
via jumper cables.
