Ahhhh - now we may be getting somewhere.
George - you said that it "won't turnover".
To me, that has little or nothing to do with the matter of the spark plugs. "Turn over" means that the engine is cranking (rotating) - not necessarily that the plugs are firing. An engine "turns over" before it STARTS and begins to RUN (those are the widely used terms and they are not equivalent).
Sorry to be a pain, but we really need to be clear about terminology here.
There are a lot of things needed for an engine to start and run, but my old auto shop teacher used to simplify the requirement down to three key elements:
1) SPIN (the engine must rotate "(turn over") - either by means of the electric starter motor or for an XS650 it could be by means of the kick start);
2) SPARK (the spark plugs must fire strongly - at the right time);
3) SPIRIT (the fuel system must provide the correct mixture of fuel and air to the cylinders).
So...SPIN, SPARK and SPIRIT - all related, but separate processes and not the same. It seems that you have SPIRIT and it seems that SPARK is there, at least sometimes.
What about SPIN? If the engine cranks/rotates/turns over (pick a term) only when it is connected to a car battery, then your Shorai battery may not be strong enough or you may have a high resistance contact in the starter circuit. Here are some questions on that matter:
- Are all of the main starter circuit connections free of paint/powder coat?
I mean the big wires that go from the battery to the solenoid and on to the starter motor AND the battery ground wire where it bolts to the frame near the battery too.
- Have you tried the kick starter?
- Have you turned the headlight OFF when starting?
I wonder if your starter safety relay (SSR) is working properly. Does the horn work? If not, then either the handlebar grounding is poor or the SSR may need to be cleaned. That is an easy 15 minute job - I can tell you how to do it.
On the matter of the fuse: I think that the correct main fuse is a 20 amp - but unless it blows, that really does not matter. If a 15 amp fuse is not blowing, then that is not your problem.
Hmmmmm. Don't worry, we'll get there.
Pete
