ninosboombox
XS650 New Member
Hi Guys,
Ive been rebuilding my 1980 yamaha 650 xs special 2, and have run into some problems, hoping the much smarter folks here can lend their expertise??
I have a new stator a new reg rectifier, new ignition switch, new stator, and a newer harness which was replaced in 2016 (all from mikes xs except the rotorm got that from ricks motorsports). so all pretty new, however I cannot get the slap test to work unless I ground the green wire coming out of the stator. I can either unplug the green wire and ground it to the frame, which creates the magnetic field and the slap test works (I did not start the bike with that wire grounded, only the key was on), or ground the green wire at the brush if i ground it w a wrench or screwdriver.
I do not want to start the bike just because I really am not an electrician and dont want to fry aynthing.
Also I am not sure if the wiring is going to the right place, If I match all of the wires by color the ignition button will not engage (also no slap test). I am also not sure if the old one was wired correctly either. I read that in the 79 and older you needed to unground the brushes, My problem seems like I need to ground the brushes (in order to make the magnetic field) so very confused. the old stator did not match the wire colors. heres how its wired in the connector plugs......
coming out of the harness.
the back 3 are from left to right.....
WHITE, WHITE, RED
front row of coming out of harnesss from left to right.
GREEN, BROWN, WHITE
connector coming from stator,
WHITE, WHITE, WHITE
front row coming out of stator, left to right.
GREEN, RED, GREY
I also read in the 79 and older that the red needed to be grounded, I did nto try grounding the red wire, only the green wire. (thats why I assumed the red matched up w the brown wire, but I dont know) Im running an 80 not a 79, so not sure if this is even valid on my model.
as I mentioned if I match all of the colors, when I turn the key only the brake light comes on, no buzz sound by the battery and does nothing while pushing in the ignition button.
The only light at the end of the tunnel is the behavior when I ground that green wire. Im really hoping I'm a big ol dummy and its something simple. would super appreciate any help. been through curlys posts and replaced basically the whole damn thing, should have just gotten the permanent magnet option, but didnt know I was going to place bit by bit. heeeeeeeeeeelp!! thx guys
WHITE, WHITE, RED
GREEN, BROWN, WHITE
WHITE, WHITE, WHITE
GREEN, RED, GREY
