racerdave
^ Gone not forgotten ^
I have a new Daytona bar to sell if you are interested.
Take the screws to Lowes and see if they have replacements. A helpful employee and some nuts to go on the screws you have will let you know in short order if they have what you need.
Going from the roto tiller bars to just the Standard bars requires a bit of creative re-routing.....you've gone quite the extreme. Not sure how those bars work when the unexpected need for a quick response occurs.
When you say creative re-routing what do you mean? I'm trying to re-route the clutch cable now and don't want do anything wrong.
Do you think the "standard" bars are unsafe?
Thanks for the info.
Today's issue is a leaky petcock. Not sure if I should replace the petcock or just the rubber pieces inside. If I replace the petcock do I need to replace with a vacuum style that's on there now? Hope everyone is having a good Sunday.
When you say creative re-routing what do you mean? I'm trying to re-route the clutch cable now and don't want do anything wrong...
- - - I was going to order this:
https://www.mikesxs.net/product/29-6507.html
Does it make the front lines into a one piece hose, or do I need to order an upper piece and a lower piece? Is there anything else I need? I am going to order new front brake pads as well. - - -
Hi shade,
read the small print, eh?
The MikesXS catalog page for that hose plainly says it's only 20" long so yes, it takes two of them to be a direct replacement for your stock hoses.
Stainless (to be exact, teflon lined stainless steel wire braid reenforced) brake hoses are an upgrade anyway.
What else? If this is to be your first try at brake bleeding, patience.
And a length of plastic hose and a catch bottle.
And read all the bleeding tips on this site.
And don't spill DOT3 or DOT4 brake fluid on the paint, it's a pretty good paint stripper.
So what about something like this? - - -
If the gas is flowing in all three positions the piston plunger on the rubber diaphragm isn't sealing?
Hi shade,
thieving bastards, eh? NJ DMV, that is.
It costs Mikes the same to mail you nothin' as it does to mail you somethin'.
Shoulda ordered the stainless brake hoses too so you'd save on shipping.
And ordered their manual petcock that fits your tank.
The petcock casting in the photo looks like it's FUBAR.
