Getting close to time when my project bike ('80) could maybe be started up. I still need some parts, which have to wait til my tax refund (next week, I hope) so I'm trying to do all I can beforehand that doesn't require purchasing parts.
Pulled the carbs off yesterday. The original carbs for this bike are gone, as I used them on a '79 I used to have. So I got these replacement ones from eBay way back then, thinking I'd have them to use whenever I did get to this bike. Which is NOW!
Glad I got them when I did, as they are in really nice shape and I only paid $10 for them. (several years ago) But these have never been on a bike of mine before, so this bike never ran with this set of carbs on it.
The idle screw covers have never been drilled out. And it really appears the bowls had never been off before yesterday either, as the screws were in perfect shape. The outside of the carbs was real cruddy, just from sitting wrapped in an oily rag all these years, but the insides were amazingly pretty clean looking. The bowls were kinda brown, but not anything you could call "sludge".
There's 3 things I DON'T want to do.
a. remove the top and mess with the diaphragms
b. remove the needle jet and floats
c. (not sure about this one) mess with the idle screws
I have blown through everything so far with carb cleaner and air from compressor. Poked through what I could with a piece of wire. So far, no holes have appeared clogged.
I lost one of the damn pilot jet caps. sigh....
and I deserved to lose it. Blew the 1st one off and in a few minutes - get this: I FOUND it. In a bunch of leaves.
Like a dummy, later I blew the 2nd one off and tried to follow its arc as it flew and I could tell where it came down - but it bounced and I couldn't tell where....so it's really and truly "lost".
Of course I'll find it in like 5 years....
So I ordered new ones. They were a little dry-rotted anyway, and did not fit snugly.
I'm guessing the diaphragms are in nice shape.
But eventually I guess I might need to access this area if I have to try and shim these needles.
Also, I do worry a bit that the area under the idle screws might be clogged, or that that tiny o-ring is also dry-rotted or otherwise no good.
But I'm also thinking that since that area over them has never been drilled out, hmmm...maybe everything in there is in nice shape.
Trying to remember from the old 34's I had, where the hole is, in the tunnel, by butterflies maybe? that accesses that area.
Wondering if I could just squirt carb cleaner in and let it run back out and that would be enough of a cleaning.
Trying to weight the risk and annoyance factors.
It's easy enough to pop these on and off, so I think I'm going to go forward like I said and then if there's a problem, pull them back off.
just thinking out loud......
ps: it just seems like there could be sooooo many reasons why this bike probably won't run.... be funny if it starts right up.
pps: another thing occurred to me, re: the elec starter. To use the starter, why must I have the starter solenoid at all? why can't I just touch the loose end of the starter cable to the pos terminal of grounded battery? Wouldn't that make the starter turn the engine?
I'm just thinking of trying that at first, before I finish wiring it completely. Like wire it as a kick only bike, then touch starter cable to battery to use the starter. Then when it runs and all, go ahead and wire in the starter solenoid and a button.
Is this ridiculous? tell me why?
I'm sure there's some huge reason, I just can't think of it.
thx, and Happy Monday
